2001 dodge ram 2500 a/c when operating on max air it runs fine. When you run it on regular air or vent mode after short period of time it stops blowing cold air it only blows warm air. We have already replaced our lines and supposedly there are no leaks in it and the freon is full
You may need to replace the reostat in the heater box. Do you have the hi speed only? Only have off and I, then it is definitely that switch in your box. You can easily replace it.
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
it sounds like the fuel pump to me also. when you first start the truck the fuel pump builds pressure in the system and as you drive the fuel pump can not keep up with the demand of driving. you should find a service station that can test the pressure that the pump is putting out to make sure
