Sony Cyber-Shot DSC-L1 Digital Camera Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DSC L1 is not supporting 4GB memory stick???????????? Says memory card problem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
117
Points
My camara screen became whitish colour when i menu check. Now always white colour.
Anonymous
Level 2:
Scholar:
  • Expert 94 Answers
  • Posted on Sep 26, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
94
Questions
0
Helped
33225
Points
191
    Please disregard the 'Busy' message which may appear on the LCD screen during MPEG movie recording in VX Fine mode. Recording and playback operations, as well as recorded data, will not be affected.
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
1helpful
Does the DSC T1 Support memory card bigger than 1GB
Yes. The maximum size memory card you can use in that camera is 4GB
(of course you need a sony memory stick pro duo) no other cards will work.
thanks for asking!
1helpful
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Where can I find a memory card with more megabites of memory?
The sony cyber-Shot Dsc F828 does not work well with memory stick that are more than 2gb. I have used 4gb memory stick, but realised that it failed to record most of my photos. Other are recorded but hard to extract. I would recomed 1gb stick. Keep more than one
6helpful
4answers
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Will DSC-T1 accept a MARK 2 memory stick?
NO, DSC-T1 will not accept such big memory card as its hardware supports maximum 2GB card memory that is more then enough for it because its 6 mega pixel camera.
Can I use 4GB Sandisk Memory Stick Pro Duo in my Sony Cyber shot DSC N1 Digital Camera''
Yes, a Memory Stick Pro Duo is the right card for this camera. The manufacturer shouldn't matter.
Sony dsc 200 8.1pixels
Camera does not support 4GB memory stick. Please use 2GB memory as maximum capacity.
DSC H9 Memory stick
Try formatting the memory card with your PC and an external card reader and then try again.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
