The
Steps for Newer Style Console Calibration
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
The
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
"F" appeared
in). Troubleshooting the failure would be the next step
The
Steps for Newer Style Console Calibration:
Locate
the calibration area on the rear or underside of the console (a
hole, near the console's center, that goes through to the
electronics board. (This hole should not have a screw
in it.)
Insert a pencil
(eraser end), into the hole and feel around for the cal button
(will click when pressed).
Press the
button 2 times (with the pencil eraser). The first click
should show CL11 in the console, the second click should
show CL21.
If the process
was done correctly, and CL21 appears in the console, you are in
"calibration mode." The next few steps consists
of pressing buttons on the console and observing settings.
This will not require any other tools.
Press ENTER.
CL22 should display in the TIME window and (??) in
the SPEED window.
Press ENTER. CL23
should display in the TIME window and (??) in the SPEED window.
Press ENTER. CL24
Press ENTER.
CL25 should display in the TIME window and (??) in the
SPEED window.
Press ENTER.
CL26 should display in the TIME window. You should
then see the letter "E."
Press ENTER. You
should see "SS" or "55" in the console.
Push the
treadmill.
Push the ENTER
button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
the incline should self test by raising to its
highest incline position, then lowering back down to its lowest
position.
Once the incline
test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is
ready for use.
If
the letter "F" appears in the SPEED or INCLINE window when
the power button is pressed 2 times, the treadmill is
indicating a failure somewhere either in the SPEED or INCLINE
(depending on the window the "F" appeared in).
Troubleshooting the failure would be the next step.
We found out we had to have a new console. Thanks anyway for the reply.
No. It was the console that has to be replaced.
do any buttons work at all? The start buttons?
Incline button works. Sometimes when I plug it back in the belt runs one mile per hour but still no buttons (except incline) work.
Also, if I hold the incline button down I can press any button on the consul and get a beep. I'm assuming then that all the buttons area able to receive or send a signal. I wonder if there is a short in the incline switch or motor.
