I have Saeco Incanto Sirius machine which I bought from auction and has 1 year warranty. A few days after the purchase it had the above problem and I tok it to the company that gave the warranty. He said it was blokage and fixec it. Now after a couple of months I have that same problem. Before i take it back, pls advise if this is a on going issue with Saeco? Also my friend has an earlier Saeco model and his machine has real fine grind but mine is not that fine-pls suggest what can I do? I have put the grind on the sallest "dot".
my e-mail [email protected]
Pls assist.
Thank you thank you!!! This problem has been irking us for months! The people in our company adore the coffee the Saeco Incanto Sirius makes so we just lived with the leak. The fix was such a simple thing, heh.
I used a cable tie to clean out the hole. The hole is very small - a design mistake, I'd say - and when I unclogged it I could see the cable tie coming out and coffee sludge flowing into the drip tray.
If you remove the brew group there is a white nozzle with 2 o-rings inset in the machine. Below this, there is a space where overflow water runs and drips into the drip tray. There is a small hole that allows water to flow into tray. This can get clogged with grounds and then it will overflow and leak under the drip tray and under the machine. Clean the grounds out of the hole when it does this.
Cheers.
where is this hole? I have the same problem with water leaking onto the counter tip. Please help
I could not find this whole after taking the brew group out. But the brew group badly needed cleaning. Where exactly is this hole?
