Televison & Video Logo
Posted on Dec 17, 2007
Tuning in SKY remote control with Orion TV
Unable to tune in the volume control of the SKY remote control with Orion 37" LCD TV 37094 C.
Model number does not appear to be on the SKY model list or an equivalent number.
Is there a generic or universal model number that can be tried to tune into the SKY remote control?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
493
Points
0
Buy a better telly
looooooooooooooooser
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
2helpful
Tuning bush tv
Because you haven't programmed the Sky remote correctly.
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be pationent
I am renting a house here in Ireland and the TV is a 19" Orion but there is no remote control to tune in the channels can you please help me
Hello
you haven't specified nothing about the model number of your Orion TV. it is needed for us to post a solution before you. Each and every models of TV has different proceeding for tuning. so repost your problem with model number or send me the mocdel number of your Orion Tv by FixYa. OK.
I have a orion 37094 tv and I have moved and I have no remote control or manual to tune in my television. I have tried to tune the televion in by going into menu on the side of the tv. I am unable to...
Hello
I've the operation manual of your Orion 37094 model LCD TV in pdf format. It comes over 4.3Mb and an Adobe Reader 8 document. If Fixya allows you to contact me do so. I'll give my email address. Through Fixya's website it cannot be send to you, I've enquired about it to them. You just request them to allow you to contact me. Ok
[email protected]
[email protected]
1helpful
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
My sky remote just newly stopped working, It still works on the tv but when i press tvguide it puts the tv to ch 1 and thats it. Why wont the tvguide work
first of all I would like you to press the blue sky button on the top of your remote. Now press you tv guide button. If this has sorted it Great if not read on!!
what I am going to talk you through now is resetting your remote:
TV
RED + SELECT (flashes twice)
999
now press the blue sky button at the top of your remote now try the tv guide button. this should work no problem now.
now to the small matter of tuning your remote back in to work your volume etc
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
2helpful
2answers
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2answers
Sky remote
Orion
0549
322,383,263,205,039,065,053,205,348,349,392,544,572,
more..
054
Try this maybe it will help
1helpful
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Tuning in my orion tv
Do you just mean to select channels, or do you need to have it search for active channels (programming mode)? If just select channels, then most remotes have channel up & down buttons, in addition to the number pad. To select by numbers, use 2 digits: 04, 06, 08, 10, 22 and so forth.
If the set needs to be placed in the setup or autoprogram mode to search for active channels, then the menu functions must be used.
You may be able to find an online manual on Orion's website. Use your TV model number.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
