Good I am sorry the other post can not be accessed...send me the info to [email protected]
As far as the other questions:
plus is says it has a wire for immobilizer bypass. do you think it will work without disabling the factory one? It may but it will not be good idea in the long run…it is up to you, my recommendation is to use one not both.
first i need to know if my car has a factory immobilizer and the aftermarket alarm has a wire for immobilizer bypass can i install the alarm without disabling the factory immobilizer? See above.
I will await your email and reply to it to let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
This is simple follow the wiring and look for the fuse and take the fuse out that is the best and cleanest way to do it so you can reinstall it again in the future if you need to, let you know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
If it is standard feature in the car look at the fuse box or you look in the front just look at the unit and follow the wire connected to it and you will see inline fuse not in a box…you just need to follow it as each car has different system but same method. I did not get the attachment yet, let me know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Still no mail ([email protected]) the unit must have a fuse it is standard, if you cannot located then look for the hot wire going to the unit and disconnected and start the car after you reset up your onboard computer if you have the test units use it if not just take the battery off for about 10 min and connected again and see if you will get check eng. Light on, and let me know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Just got it now I will work on it and e-mail it to you …you can close this ticket now. let me know if you need any other what you asked if not, please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Yes I did and working on it...please close this post now as I will email the document to you...Thank you again for the opportunity to serve you...God bless
how would i be able to disable the immobiliser
where is this fuse located? did you receive the diagram?
i dont think my car has a separate fuse for the immobiliser because its programmed by the body control module and i think it has to be reprogrammed or something like that?
i sent you the diagram did you get it?
thanks
