Acer AL1715 17" LCD Monitor Logo
Posted on Dec 17, 2007
(strange) volume control icon stuck in the middle of my LCD monitor and the buttons on the front of the monitor are frozen and will not work?????
Woke up this morning with a small gray volume control icon smack dab in the middle of my Acer LCD monitor. I don't know where it came from and it will not disappear nor can I click on it. Also the buttons on the front of the monitor are frozen but the green light is on. HELP!!!! I've been working on this problem all day!
  • 3 more comments
  • swordy Jan 26, 2008
    exact same problem here on a AL1912. Is very annoying. The solution supplied by Santo here does not work, (thanks anyway Santo). Please, anyone?
  • marky11 Feb 29, 2008
    Same issue with a 1912. It appears that the 'volume down' button is stuck on, but can't unstick it. Seems that if I hold down the 'volume up' button then press off, then on again (still holding down 'volume up') it'll stay away.
    It's been happening off and on for a while now - often happens when its humid.
  • julees May 25, 2008
    Volume Icon in middle of screen , will not allow me to click on it or close it. Would some -one please advise. Thanx Jules.
  • kelly7602197
    kelly7602197 Sep 09, 2012
    I have the same problem on my monitor. It's a gray volume box with a yellow speaker that you can't even click on!! WTF annoying. Gotta be a virus...
  • Anonymous Mar 20, 2014
    the gray volume icon will not leave the middle of the screen
Marinos Philis
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 18, 2015
Marinos Philis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8541
Points
13
I had the same problem. Tilt the screen is pressing behind the buttons problem fixed.
A
Anonymous
Buy a new Lcd screen but not ACER try different brand
A
Anonymous
Restart the computer. Right click on the task manager > Task manager > End all the programs in Applications folder.
All the best.
Santo
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
1helpful
I have compaq tft8020, from last 2 days i m facing problem. lcd is showing automatic"adjustment" between cable 1 or cable 2 with in 1 second.pc display is showing, but adjustment is continusely showing and...
mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
2answers
MY MONITOR CONTROL VOLUME KEEPS COMING UP ON MY MONITOR AND I CANT MOVE IT ,WHY IS IT DOING THIS ,IT IS IN THE MIDDLE OF MY SCREEN
it is a volume button problem. first you ensure that button is stuck or not & you can checked it from computer store.
HOW DO I TURN DOWN THE VOLUME? I DOTN SEE THE VOLUME BUTTON
This monitor has no volume. The volume is controlled by the computer connected to the monitor, and not controlling the monitor itself.
To regulate volume on computer, click on the small audio icon near to the clock, or locate the audio settings icon in control panel.
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
1helpful
3answers
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
No sound on lcd monitor
Hi...there,
Very simple just plugged your audio cable to your lcd monitor jack , then do the same to your pc audio jack. From the front (with picture of a headphone) or from the back (green audio jack) To settings the volume control open the on screen display from the lcd monitor and look for volume settings. or go to your toolbar bottom r/h side look for the icon of a speaker and click on it...and that it... have nice a day!
1helpful
Loss of volume button
click on start then go to setting then control panel in control panel go to sound and audio devices i n that you will see volume tab in volume ther is option called place volume icon in the task bar just select taht and apply it it will show spk icon on your task bar but be sure that your sound card is properly installed. pls get me back if you need further assistence. bye
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
