My friend has a Maxtor 6E040L0 - Fail. Return Code:7 Not booting into XP - Unmountable-/boot_volume. chkdsk worked on 3rd attempt yet keep getting same error code up. have tried Xp safe mode etc. Any Ideas appreciiated??
Sounds like you need a new hardrive, i would reccomend getting a replacement drive and then hooking up the dead/dying hardrive up as slave to recover what you can, disabling S.M.A.R.T might get you to a situation where you can get what you need and then bin the drive
This is caused by a corrupted boot partition on your hard drive. If you have a windows 7 DVD or if your computer has a recovery partition you can boot in these and go to the repair option, select command prompt and type chkdsk /r to attempt to repair the damage. Comment back with your computer make and model and what operating system and I can give you better directions
The cause is a corrupted boot.ini or bad harddrive. Try running chkdsk from the command console. Check the links below for more info on how to do this:
Unmountable Boot Volumes almost always indicate a failure of the hard drive. You can try running CHKDSK /R from recovery console or a clean installation of Windows. If those fail, replace the hard drive.
It sounds like you've had a fatal error - you can reboot the PC back to factory setting - this is called a hard reset - but before you do that - unplug you tower and clean it out (dust & dirt) - once you're done with that - restart you computer and press &hold down the "Ctrl" and "F11" button at the same time - this will let you reset the PC to the original factory configuration.
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps. Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks 2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console 3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access 4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter 5) At the command prompt, type CHKDSK /R and then press Enter 6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
