My black & decker smartbrew 12 cup coffee pot is not working right. When I plug it in, the clock flashes, and if you try to set the clock, the numbers race all the way to 12:00 and then the auto light begins blinking. Nothing turns on the pot or helps, not even pushing buttons. It won't make any coffee or let me program it, and I dont have the manual since it was a hand me down from mom.
Try see in manual https://mans.io/item/black-plus-decker/cm5000gd
SOURCE: Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
SOURCE: black and decker spacesaver coffee maker
I need the replacement part of the coffee maker that keeps the water in the tank, black round gasket with a spring tell me more or where I can go and get replacement parts for it.
Thank U
Star Litle
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
SOURCE: filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
