Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
SOURCE: antenna alternatives
Hi if you go to any electrical repair shop they can sell you an adaptor to change the fitting also you can buy an end that you can fit onto the antenna yourself they are easy to do and its something you can do yourself and would cost next to nothing to do
