Question about Coleman Powermate Premium Plus 6250W Portable Generator
ENGINE RUNS BUT NO POWER TO OUTLETS
WE HAVE REPLACED STATOR,ROTOR,RECTIFERS,BRUSHES,AND VOLTAGE REGULATOR NO RESULTS I HAVE TRIED TO EXCITE ARMITURE BY ADD 12 VOLT CURRENT NO RESULTS NO POWER TO 12 VOLT DC OUTLET EITHER COULD REALLY USE THE HELP THE UNIT IS A TROY BILT 7800 WITH BRIGGS ENGINE MOD # 030237 FOR THE GENERATOR SEEMS LIKE EVERYTHING IS NEW FEELS LIKE SHOULD WORK
    President:
  • 1,730 Answers
When you flash the field, are you going + 12 volts to the top or right side brush? Negative to the other brush? Try three times for 2 seconds?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 26, 2009
SOURCE:
My bulldog bde 6500tw generator run. just won't generate power
If it has sat, it may have lost it's rotor residual magnetism.
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Feb 27, 2015 | Electrical Supplies
Powerstorke 6250 running but no power outage
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Feb 21, 2015 | Electrical Supplies
I have a northstar generator that runs but not putting out any power
Feb 11, 2015 | Northstar Electrical Supplies
7500 champion generator used breakers were tripped they wouldnt reset but ran great good voltage for about 3 weeks now it still runs great but the voltage meter bounces on 0 wont power nothing
Dec 26, 2014 | Electrical Supplies
3500 watt generator runs but no electricity
Oct 15, 2014 | Electrical Supplies
I have a PM0496750 it runs well but does not produce electricity
Oct 11, 2014 | Electrical Supplies
My generator runs but will not generate electricity
Why does my generator run but doesn't put out any power?
Sep 05, 2014 | Electrical Supplies
My 7500 watt generator doesn't produce any power
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
I have a coleman powermate vantage 7000 with no power output. Briggs engine runs fine. I have replaced the rotor and the bridge rectifer and still no results. I think maybe I got a bad rectifer.
if this unit doesnt have a battery you will have to excite the stator to create an magnetic field refer to manual for excitation leads differ from unit to unit. also 9 times out of ten you will have a burnt pole shoe connection on your line leads from the stator check with ohm meter to ground after isolating if no resistant from leads to ground the stator is shorted and will need replaced. Goodluck
Jun 24, 2010 | Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
766 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Sheldon Dedek
Craig Butler
Craig Butler
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
