Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Leaving streaks of grass in middle of mower
My new 54" cut husgvarna is leaving grass streaks in the middle of the mowing deck. have to mow over area at least twice to eliminate the streaks. does anyone have a similiar problem or a solution to the problem
  • 437 Answers
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Posted on Sep 25, 2009
  • Timothy Milam
    Timothy Milam Apr 26, 2018
    Afraid I strongly disagree with your thoughts on the reasons why these decks leave more than half of the grass uncut.
    Too many of us are complaining about the same issues, and they are related when it comes to the uncut grass, and the severe clogging of the mower decks undersides.
    To understand the issues that are at hand one must know a little something about airflow, and also you really have to flip deck over, and look at the engineer's design that they used in trying to achieve proper lift and discharge of clippings..
    Your thinking would be correct in a lot of cases, but here in this case it is way outta the park as to why.
    Having just viewed the YouTube ad they released on the new design, I see they totally changed the underneath layout of the new Clear Cut fabricated decks...
    What upsets me, is that they left us that bought the older mowers with the old deck configuration hanging, and now we're stuck with a inferior POS. Unless some of us are capable of re -configuring the decks ourselves that is, and even then we're screwed, because then 10 year warranty is null and void I'm sure..
    On a whole I feel they got us from the start, because at the price we paid for these pieces of equipment the value is not even close to what we paid.
    Between the poor design of the fabricated decks, the too light of grade system they used to try and hold the weight of it up, and keep it in proper adjustment. Not too mention the added weight of all the clippings that it is unable to discharge. Which in of itself, is a great big hit in the back pocket of us, and they've lost a goodly amount of loyal customers due to it all.
    Then there's the substandard steering system they've stuck us with too, add it all up they totally dropped their standards, and cost them the many of us that bought their brand of equipment in the past..
    Which I'm sure they'll never feel for many years to come, because of the growth rate of our population. So that there will be plenty more to follow in our footsteps for them to gain their Profits off of for years to come..
    Sincerely,
    Timothy J. Milam Sr.
    Greenville, Texas
    Husqvarna YT42XLS 24 hp kholer V twin 42' 3 blade fabricated deck
    450 Chainsaw
    460 Rancher
SOURCE:
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 42 in riding mower and i need to know what could be causing it to mow grass uneven leaving a high streak in the middle of a cut?
Possibly blades need to be sharpened.also,you may be trveling too fast.only the first inch or two of the blades do the cutting.if the grass is higher than average,and you travel too fast,and the blades are dull,the unit cannot keep up with the rat of grass it has to cut every millisecond.hope this is useful.if it persistz,try being more specific and i will try again.i am a certified small engine mech.thanks,bart
Sep 22, 2011 | Garden
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
Need to know how to properly set the guide wheel heights on the mower deck and the blade height for proper mowing heights.
with a marker,mark on the front of the deck where the blade height is, and do the same on the back, do this so you can get your measuring tap in there.play with the adjustments till you get the front and the back the same height,it should be around 5 inches florida up north 3-4 inches. it is hard to find a mower that can be set for 5''. the shorter you cut the grass the more watering it requires. check your grass type and search it's cut height and food requirements for you area or growing zone, for a happy healthy lawn.. jay the pump repair guy in longwood Florida
May 26, 2011 | John Deere 26HP Hydrostatic 54" Riding...
The blades stop turning under a heavy load on my Craftsman 42" mower deck. Is there an adjustment that can be made?
"the adjustment" is to slow down in high grass areas. alternatively mow more often so the grass does not get so high between mowings
Apr 12, 2011 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
2,448 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
