Question about Casio G-SHOCK 200M DW5600E1V Wrist Watch
Replace battery on a casio gshock.
I've replaced the battery but the display wont come on?
is there a spring or a reset command after replacing the battery
something i missed or did wrong?
  • julial961 Sep 06, 2008
    I have the same problem , how do you short the reset button ? Thanks Antony
  • Ralph W. Holbrook
    Ralph W. Holbrook Apr 06, 2009
    I changed the battery in my casio DW5600E G Shock, and now i have no display, can someone help me
  • 111 Answers
Good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Posted on Sep 02, 2008
Using metal tweezers, connect the pad on the board of the watch labeled "AC" with the top of the battery or the strap holding the battery in place. You can try a bent paperclip as well.
Posted on Oct 20, 2008
SOURCE:
How to reset a casio g shock watch
HOW TO set your time on a G-Shock watch - YouTube
? 0:56
https://www.youtube.com/watch?v=_cwKYE1JMXM
Apr 8, 2013 - Uploaded by JseanSSent
This is a how to video on setting your G-Shock. ... Casio GSHOCK GA110GB-1A REVIEW ' How To Set Time ' LIGHT DISPLAY - Duration: 2:59.
Reset gshock - YouTube
? 1:41
https://www.youtube.com/watch?v=s6XVUqui6Nw
Jun 7, 2014 - Uploaded by aswan yusof
Tutorial how to reset gshock after changing battery. ... Reset gshock .... GA110-1B Stealth Black Casio G-Shock WatchReview - Analog DIgital ...
Dec 29, 2015 | Casio Watches
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.f04e221b-19b4-4c75-826f-ee7856675bed.jpg
Feb 26, 2013 | Casio A168W Wrist Watch
Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
I have just found this site, it has all sorts of watch straps for all casio watches.
I am sure that you will find it useful
www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
Feb 20, 2012 | Casio GShock Giez watch #GS10011A Watch...
Where can i get a rubber Gshock Glide replacement strap from?
You can buy them directly from casio , just google casio parts and you will come accross their parts website. Fortunately casio is one of the most parted watch around with people always customizing their gshocks
Jan 24, 2012 | Casio Watches
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
How do i replacs the batterie in a g-shock illuminator
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
Aug 26, 2010 | Casio GShock Illuminator watch
Poor cassio watch display
You don't say how old the watch is and whether it has always had a display problem. I have seen several watches with weak displays, but generally they are older watches and I suspect the problem involves a corroded contact somewhere in the "movement". You might want to visit the Casio website and download a copy of the manual for your watch. It may say something about the display. If you watchis fairly new it may still be under warranty and again, contact Casio to see what you need to do.
Jun 13, 2009 | Casio G3011 Duplex LCD Watch
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio G-SHOCK 200M DW5600E1V Wrist Watch Logo
857 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
