Coleman Powermate Premium Plus 6250W Portable Generator Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have a Coleman Powermate (Model PM0525303) with a 10 HP gas engine (Tecumseh Engine Model HM80-100). It starts right up and runs fine for about 3 or 4 minutes. Then the engine starts to pulsate (i.e. RPMs go up and down) and subsequently shuts down almost like it ran out of gas. Sometimes, the engine might backfire shortly before shuting down. I use a fuel stabilizer (Stabil) , but I did noticed the plug had carbon deposits on it. So, I replaced the plug, drained the gas and replace it with new fuel (including "Sea Foam" fuel stabilizer/cleaner this time instead of Stabil). This did not solve the problem. The engine starts right up again when I set the choke and pull the start cord.....but the it always shuts down around the five minute mark. I tried this several times to get the new fuel and cleaner into the engine, but it always shuts down around the five minute mark. Help!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5169
Points
5
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Anonymous
Level 2:
  • Expert 157 Answers
  • Posted on Sep 25, 2009
Anonymous
Expert
Level 2:
Answers
157
Questions
Helped
101013
Points
261
The carb may have to have a new kit installed. or theres a good chance the coil is heating up and may need to be replaced. also look for a low oil pressure switch on the engine there bad about going bad. when you find it disconnect the wire to it and try it and see if it runs longer.
2helpful
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
8helpful
2answers
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Coleman powermate with 10 hp Tecumseh. Never started before this attempt. Full gas and oil. will not start. No spark to plug, checked with plug out. Engine switich on position.
There are a couple of switches on these things, and their positions and the little icons on them are NOT intuitive - well maybe they are intuitive to the under-20 crowd. I lent mine (which starts right up) to a friend who spent an hour or two pulling the cord before he noticed how to turn it on. I'm not trying to be a smart-alec. I hope this helps.
3helpful
Need to know what oil to use in 10 HP 5000 tecumsah engine - goes on our generator and I lost the manual
It depends on what temperature range the generator will be operating in. Below is a chart from Tecumseh that shows different oils for different temperature ranges. It says on their website to use a high quality brand name oil so you don't have to get actual Tecumseh oil.25b21be.jpg
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Need to know what type of spark plug i need for replacement
Try an RJ8C, thats a fairly generic plug for the 10 hp Tecumseh engine that should be in your generator.
4helpful
2answers
Coleman 5000 watt generator Tecumseh 10 hp engine. Surging r.p.m. Carburetor has been gone through 2 times, and still not correct. Any information will help!!!
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
1helpful
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
