LG Vu CU920 Cellular Phone Logo
Posted on Sep 24, 2009
How do I transfer pictures and videos from my LG VU Mobile phone to my PC, and vice versa?
  • lestatdelion Sep 25, 2009
    I hook up my phone to my laptop via USB cable and I cannot figure out how to get the pictures off my phone and put them on my laptop.
  • Anonymous May 11, 2010
    GENERAL PROBLEM
    » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
    UNLOCK CODE
    » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
    simuli2
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
880
Points
Its easier to get a micro sandisk card & put into ur phone & easily transfer files back and forth from ur phone to ur computer. thats what i do & its very simple.
1helpful
Need to download pictures from phone
You can use your data cable to transfer files to PC and vice versa also use the bluetooth to trasfer files between your computers and phones
Hello! I have an LG-T310i I bought it last Saturday, I am still trying to learn more how to navigate the applications, I would like to know how I can transfer my files ( pictures, music ) from my LG-T310i...
Music transfer is not supported by Lg cookie. I had tried everything the only way is that connect your phone in usb data transfer mode and copy files on a memory card.
Aug 30, 2011 • Cell Phones
2answers
How do u put pictures from your phone onto a computer?
HI
if you have bluetooth you could do it with that
or did your phone come with a usb cable and disk to enable the transfers
either way did you get a user booklet with your phone
if so in there it should explain how to do it
if you still cannot transfer the pictures over to your laptop
please come back to us telling us
your operating system and the make and model of your phone
many thnaks
Want to download music and pictures from phone to my laptop
Simple as ABC, you must have LG USB Connector or blue tooth device, then LG drivers or LG PC suite then you can transfer your files to your CP vice versa.
Want to upload pictures from a computer but i dont know how
You will need PC Sync Software that will allow you to connect the KG290 to your Computer through the USB Port. The PC Sync Software is supplied with the Disc provided with KG290.
To connect your LG handset to the PC all you need to do is download PC Sync software using LG Software Updater Application. This can be downloaded from “Products > Manual & Software.”
Click on the link below to download the PC Sync Software:
http://www.lg.com/au/support/product/support-product-profile-mobile-redux.jsp?customerModelCode=KG290&initialTab=documents&targetPage=support-product-profile
Please click on "How to install the LG Mobile Phone Software Update Tool and download drivers" to download the PC Sync Software.
Once you download and install the PC Sync Software, you are ready to transfer the pictures from Computer to KG290 or vice-versa.
1helpful
6answers
Data transfer from the LG vu cu920 to a pc (contacts, photos, etc
have u tried saving your info to your mirco sd card and using sd card reader to get your info to your computer
Can you use a bluetooth doogle to transfer pictures from a LG-VU cell phone?
yeah sure u can use their r many versions go for a new version nd they are IVT BLUESOLIL,ENTER their r many more available brand in market after installation of bluetooth drivers pair ur mobile with pc ur work is done......
Pc to mobile and vice versa
i think u cant find the sophisticated softwares pertaining to samsung in the net . So do a thing . get a bluetooth device connected to ur pc. Install the necessary drives for the bluetooth device . now switch on the bluetooth in ur phone ,,,, and transfer ur pictures via bluetooth
2answers
Picture transfer
hi confused123,
you don't need to be the most computer literate just to transfer pictures from your mobile to your PC or vice-versa..all you just need are: your USB cable and your V3i.
There are a lot of ways of transferring data but this one i am going to tell is the most easiest way.
From PC to Mobile Memory Card Only (Vice-Versa)
Using USB Cable
1. On your V3i, go to:
-> Settings
-> Connection
-> USB Settings
-> Default Connection
-> select Memory Card(if you have one)
2. Connect your mobile to your PC. Your PC should detect your mobile memory card. If Pop-up window appears asking for some actions you should take, you may cancel it or select the "Open Folder" list from the list box.
3. If no pop-up window appears, Open your Windows Explorer or the My Computer at your Desktop.
4. You must see your mobile memory card now from the list of icons. It will look something like a drive letter "E" or "F". If you have a single hard drive with no partitions, single CD or DVD drive, your hard drive is your letter "C", your CD or "DVD" is your letter "D" and your mobile memory card will be your letter "E".(weew! This is the reason why I don't take a teaching career).
5. Open that drive and you will see one folder inside named "Picture". Open it.
6. Inside that folder you should see your pictures from your mobile memory card. (Unless it is empty)
7. Your pictures is now ready for transfer.
Transferring files is easy as copy/cut-and-paste. You can transfer pictures from PC to your mobile as easy as that and vice-versa.
If this solution is inappropriate, please notify me and i'll try to make a revision of my "lesson-plans"!
I hope this would help!
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
