I have a fusion active dual 12'' encloser sub box and i got all the wiring but i dont nmo how to wire it up can anyone help?
OK. (1) The RCA's plug into your audio-In on your amp and the other end of your RCA's plugs into the back of your cd player's audio-out. (2) The small blue wire is the "Remote wire" the one end is wired together with a blue wire in back of cd player other end to amp..To attach wire "remove some of the rubber insulator on wire about a 1/2 inch then twist wires together and put electrical tape to cover or wire nut if you have one." (3) "Ground wire" this is the black wire one side to "amp - neg" and the other end to frame of vehicle. " find a bolt in trunk and put the end of the wire around that and tighten bolt" but before putting bolt on take sand paper to the metal frame where the bolt hole is and sand all the paint off! (4) Last Power wire the "red wire". Cut about 12 inches off power wire plug one end to "amp + pos" the other end to the fuse...Now with the rest of the Power wire plug the one end to the otherside of fuse and run that threw car either driverside door or underneath the dash to the "+ pos red" side of battery.
Then your done! Good luck! and wire in that order and you want blow anything! Give me a thumbs up if you like!
