screen protectors are only plastic covers that protects the screen from scratches and such.
It is not possible to buy a new LCD screen. Since the camera is now Out of Warranty a repair will cost 48 pounds with KODAK.
That really sounds like the LCD screen is cracked. The front will not feel cracked because of a clear plastic cover sheet but behind it is the LCD panel. The liquid you see is part of the screen leaking. The LCD actually means "liquid crystal display" and that is what you are seeing leak out between the cracks in the panel. You will need to have the panel replaced to clear the problem. You can get the panels from Ebay if you want to do the repair yourself. This type of repair is not covered under the Acer warranty. If you have any questions just use the email address below.
hi
If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5
OR
the lcd screen? hmm is it blank or cracked ... probably I would chuck it for the new cells are free with a contract, but if you have to ... contact the manufacturer and order and a screen and get a set of tiny screw drivers to open it .. some are tricky and you need to figure out where they hide the screws . REGARDS
Hi there. If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5. Hope that helps. Gary
