Could really use a lot more information, but to start you might
check your bios first to see if your computer is recognizing the HD, (XP will try to install just using RAM). Make sure your drive jumpers are set properly. Master, slave or CS?
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Hi, you haven't said for what operating system, but for XP. First you will need to change your primary boot device to CD Rom, to do this boot into BIOS by pressing the F1 key during initial boot fase, save changes after boot device has been selected, insert windows CD into drive and reboot. Select boot from CD, which appears during initial boot fase. Allow files to be installed, once finished you will need to delete operating system and repartition hard drive, then format hard drive. Once this completes PC will reboot, ignor boot from CD and allow PC to boot normally and it will start to install XP.
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally. Hope this helps, if not come back to me.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
put your copy of xp into the cd rom... boot up and enter setup and change the boot order to booting from the cd rom first... follow the screen instructions to install xp... when it reboots in the middle of the install DO NOT hit a key to start the cd rom... let it continute to boot from the hard drive to finish the install.
if you need further help or instructions don't hesitate to ask
first configure your hard drive in the bios set your harddrive as
primary drive then configure the booting setup you must boot first the
CD ROM drvsave setting and exit. Then if you have a bootable disc
installer for XP any OS insert in in the CD ROM drve. wait for a while
then follow the instruction that goes out in the desktop.
