you have to make sure you give correct stereo signal source to the stereo amp input, you can confirm this by changing your audio source to Left or Right. can your amp speaker out follow the sequence?
When you are connecting this television to a signal source with a coax cable this happens. The solution is to connect with an RCA/composite cable instead and utilize the television's inputs instead of using input tv.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
does it have 2 plugs one for mic and headset or sterio plug for mono head set mono mic u would need input on phone that can accept that kinda sterio input ok for both
Make sure you are panning hard left and hard right before you export the track. Why don;t you use the roland interface and bypass the mac all together.
