My sreen is gradually turning light blue. it started in the lower right corner, went to the upper right, and now is going across the sreen from right to left.any ideas?
Can you verify the model# of the tv so I can help you out. The model# is on the back of the tv set.Can you verify the model# of the tv so I can help you out. The model# is on the back of the tv set.
You can't post conmments that contain an email address.
Goof proof...take a tape measure and measure from lower right to upper left of screen..or lower left to upper right. That'll give you your size.
I'm not sure, but I'm old enough to remember all the tv's were round. B&W 3 channels.
18" measured across. When they came out with square tv's someone came up with this measuring system..corner to corner.
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident. Hope This helps!
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Uh Oh! blue screen of death. Your light engine
has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with Sony and start
complaining, then keep complaining until they agree to pay for
it. Even if it is out of warranty.
You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Hope ya fix it!
mine started in the left top now right aswell
i think its kf-50e200a, its a 50inch
corner of television is turning blue
