Question about Canon PowerShot A630 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
The "auto" mode does not take good pcitures. It's like the camera cannot distinguish when it should use flash and when not. Then, even with the flash on manual, the pictures turn out dark when you have a decent amount of light for the picture. When the room is dark, forget a picture at all. The best pictures are when you have good light inside or out and the flash is manually turned off. The camera worked great for about 3 years; then, suddenly this summer the dark side came out!
  • pncmyer Sep 23, 2009
    Resetting the defaults didn't take care of the problem. What now?
  • JudithWWatkins
    JudithWWatkins Jul 11, 2019
    I essentially started about a month and a 1/2 agone and i have gotten a couple of test for a whole of $2,200...this is the bestcall I made amidst pretty some time! "grateful to you for giving Maine this incredible possibility to profit from home. This similarly cash has changed my existence in such an excellent measure of courses, to the point that, bypass on you!".......GOOD LUCK Click this Below connect here...................www.profitclip.com
    Brigadier General:
  • 11,967 Answers
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Posted on Sep 23, 2009
  • Ty Price Sep 23, 2009
    OK...I'm assuming the battery is fully charged. Let's try a manual reset. Remove the card and the battery...press all the buttons...leave the camera alone for 20 minutes to discharge any residual power...insert the card and then the battery. Try a few test shots. How did they turn out?
SOURCE:
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture...
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Dec 04, 2013 | Cameras
My pictures are coming out too dark
There are four ways to make the image lighter
a) more light (flash, sun, etc)
b) slower shutter speed (allows more time for light to "expose" the sensor)
c) larger aperture (bigger hole = more light)
d) higher ISO (basically, amplify the available light more).
If you are using a point and shoot camera, the flash is usually only good for about 10 feet, so trying to get a good bright picture of subjects further away won't work.
Items b, c, and d are handled by the camera in automatic mode. In manual mode, set the iso has high as it can go. Set the aperture as large as it can go, and decrease the shutter speed.
Depending on the camera, you can enable the histogram to see if the images are too dark, usually by pressing the display button while taking pictures. If the histogram is off to the left edge, the picture will be too dark.
In post-processing, (e.g. photoshop), you can use Levels (control-shift-L for auto-levels) and it will move the histogram to the right, making the picture look brighter.
Feb 27, 2011 | Cameras
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Falsh Problem with Power Shot a640
I had the exact same problem. You'll need to send it back to Canon. It'll cost you $87-94, but they'll clean it up, get the flash working, and make it new again. It's a good camera worth getting fixed.
Sep 14, 2008 | Canon PowerShot A640 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Dark pictures with flash
I had this problem before, sent it off to have it repaired 1 year ago, and now have it again. Just to make sure it's the same problem, here's a description: The flash seems to be out of sync with the shutter. Using the flash in medium or low light (in auto mode) makes the picture darker than not using a flash at all. It ruins the picture. In a completely dark room, even though the flash fires, the pictures comes out pitch black. The problem is the flash unit -- it needs to be replaced. If your camera is under warranty, Canon will replace it for free. (You pay only to ship it to them.) (You might try what they told me to try before I shipped it off, and that was to reset the camera by pushing and holding the menu button until it resets. Didn't do anything for mine, but who knows.) If it's not under warranty, Canon will offer to replace it with a refurbished newer model for a discounted price. That's my situation now, because the problem has come back. I did come across a posting that described how to replace the flash unit yourself -- it involves taking the camera apart, but looks doable. (Sorry, I don't have the link handy and I'm not sure if I can find it back.) The problem is, I don't know where to get the part. Canon has been no help on this. Anyone know where I can get a Canon flash unit for the A85? Hope this helps, and good luck.
Jul 28, 2006 | Canon PowerShot A85 Digital Camera
Canon PowerShot A630 Digital Camera Logo
433 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
