Xerox 8850 Led Printer Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you trouble shoot an ll25 error code on the xerox 8850 printer
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Dec 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
Helped
10527
Points
75
I think there is no code like ll25 pls tell me righ code
Keyur Patel
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jan 08, 2015
Keyur Patel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
26
Helped
3057
Points
ARUN BORA
Level 2:
Champion:
  • Expert 241 Answers
  • Posted on Jul 23, 2013
ARUN BORA
Expert
Level 2:
Champion:
Answers
241
Questions
5
Helped
87248
Points
457
Just try with update firmware released on
02.03.06-16 LL.24 Status Codes Removed
Xerox 8850 error code LL-12
I expect you have this fixed by now.
Look closely in the fuser area, perhaps you might see the problem.
Are both fuser rods working correctly one rod has the coils in the middle and the other has them either side so as to even out the fuser temperature. You might need a meter to answer this.
This would need Xerox engineer callout.
Good Luck
5answers
Printer error fuser temp
The "fuser" should be generating heat, to melt the dry toner-ink into the paper.
So, a "fuser error" occurs when the printer detects that the heating-element
is NOT generating the correct temperature, i.e., not hot enough to properly melt the ink.
Take the printer to a qualified technician, for professional trouble-shooting and repair.
Printer error fuser tempratore
The "fuser" part heats up, and melts the dry toner ink onto the paper, permanently bonding the ink to the paper.
So, a "fuser temperature error" means that the fuser is NOT reaching its "operating" temperature.
Take the printer to a professional technician, for proper trouble-shooting and repair.
Or, if you have a Service Contract with Xerox, telephone their local office, and get them to dispatch a service technicican to your location.
Our Xerox Phaser 4500 printer has printer cooling fan error. Call Service - Code U5
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
1helpful
2answers
J2 error on xerox xd 100 copier
hello there:
here is a link that will be able to help you out
  1. XD100 Style: Trouble Shooting Xerox brand models: XD100/102/103/104/105, XD120/122/125/130/155, XL-2120/2130 ... Next month, we'll hit the J1 & J2 codes as well as the L codes...www.enxmag.com/OLD SITE/bhorvat2304.html - Cached
Anyone help with fault code 08.007.41.122.171 xerox phazer 8400 pleas
That is normally a RAM failure. You can try going to the back of the machine and opening the plate which covers the memory stick or sticks, depending on how much memory you have. Remove and reseat the memory. You may have had a memory failure, memory dump or electronics module failure. Kind of a difficult one to trouble shoot.
2answers
Printer Error 13,327.42.16752
It Sounds like its a bad printhead but run these trouble shooting steps first.
Troubleshooting Procedure for 13,264 to 13,327 Error Code (Printhead)
Step Questions and Actions Yes No
1 Check that the ambient room temperature is
within specifications (
Is the room too cold or too hot?
Go to Step 2.
2 Ensure ground integrity
Are all components grounded properly?
Go to Step 3. Resolve
ground
integrity.
3 Run the Printhead Reservoir Temperature
test.
Did the test pass?
Go to Step 4. Replace the
Printhead.
4 Check and reseat all wiring to the Printhead.
Did this correct the problem?
Complete. Replace the
Printhead.
1helpful
Error message 07,009.42:45702
That has to do with the process drive motor timing or the maintenance kit binding.
A little involved in trouble shooting. If you want more details let me have an E-mail address and I can send you the info on what to do.
Just for clairification, you dont happen to be lucky enough to actually have a 09,007,42 code do you ? That would just be a stick ink stick.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
