Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation
0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint
adheres to surface of vertical path roller
Description
Since a type of paper that can easily
generate lint was used, the paper lint adhered to the surface of the vertical
path roller and decreased the paper feed performance of the roller, causing the
jam code "0105."
Depending on paper sources, the following jams occur.
Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor
PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10
delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry
sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry
sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2
(cassette pedestal) delay jam)
To prevent this, a vertical path roller to
which paper is hart do adhere was used for the following machines (the color of
the roller was changed from black to gray).
- iR2230 120V THF03592 and
later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606
and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW
KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V
KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and
later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW
KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V
KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and
later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596
and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW
KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V
KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and
later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439
and later/230V KFR02186 and later/230V CA SKQ01030 and later
Field Remedy
When the symptom occurs with the machine
without the foregoing serial numbers, replace the vertical path
roller.
Kindly rate me !!!!!!!!thank mate.
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
