When you do hear your LG washing machine making a loud banging type of noise on the spin cycle it could be caused by overloading or a loud that is unbalanced Or the bearing has worn out and needs replacement.
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Form the front of washer, spin drum by hand, and if it fees rough, or is rumbling, then the main drum bearings are worn.
If no noise from drum, then could be worn shockers, or the washer is not properly levelled, or concrete balance weight, I'm afraid it is a process of elmination.
Hope this helps.
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further. Good luck!
