Help.
Tappan gas range, 30 inch free standing, with electric ignition will not light.
Stove stored in inside room 7 yrs, 8 months outside covered in canvas tarp in Phx, AZ.
Cleaned the stove carefully, moved it in to the kitchen, hooked it up with new hook up parts.
It will not light on either the top burners or the oven. No sound or smell of gas, just endless loud "Click..click..click." Tried lighting with match, on pilots and burners......nothing??)
Can you help????
I had the same problem when I bought a house with a gas range. If you wait ten seconds or more there is a unit that heats up and ignites the range instead of a pilot. You will hear a click every few seconds then while it ignites the stove. I was afraid to wait because I smelled the gas. But after paying someone $100 for a service call that is what happened.
It is electrical and in the back of my stove there is a cord that goes in the wall. make sure it is plugged in. It also affects the burners however they have a light option on the dial, the oven does not.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
yes the igniter can come on telling you its ok but these igniters break down they light up but not hot enough to ignite the gas replace the igniter thankstheappliance doc
If this is old enough to have an actual gas pilot it will have a thing called a thermocouple. The pilot flame burns around this thermocouple to keep it hot. The thermocouple must be hot from being in the burning gas or it will turn the gas off to the pilot. Yeah, it's kind of a viscious circle isn't it? This is where a propane torch comes in handy, but you might do this with one of those butane matches with the long neck. Apply a flame to the thermocouple for 30 seconds or so. When the thermocouple gets hot enough the pilot will self-sustain. Be sure it is the thermocouple it is you are heating up. It is at the end of a rather thin, what looks like a wire but is actually a wire inside of a thin tube. (still looks like a wire). Might be described as looking like a hot dog on a stick in miniature form. the hot dog part being about 1/8 inch by 1 inch. and is in a bracket.
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
