Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
Posted on Sep 23, 2009
HITACHI AIR COMPRESSOR
Hi
I have an air compressor HITACHI 37kw, modelOSP-37S5A1.Now an alarm with U100 is flashing on the screen. I press reset button but it come again 5 minutes after
Pls tell how i can release it
Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1957
Points
Hitachi ec 12 14.5. 2 horse power
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Sep 27, 2009
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
17183
Points
76
What type of air compressor you have,since when you maintained it
How to set the alarm ( Discharge Temperature ) on Hitachi Next Series (V73 - Oil free Screw) Compressor?
Unfortunately, you don't provide a Model number 'V73' is Version 7.3 of the Software running the control panel. They have model number like in the front page of this manual, and in this particular Manuals website you can use the search feature.
https://www.manualslib.com/manual/1652200/Hitachi-Next-Series.html#manual
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
2answers
Plase help!VSD fault 2 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw
Vsd fault 2 is a current imbalance. Check your current readings and compare them to those on the intellysis display they should match, also check for a imbalance in amps. After that it gets more complicated using board diagnostics etc
Please!!!VSD fault 7 and VSD fault 1 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw. thanks!
Vsd fault 7 is a fault with the hall effect sensors inside the motor, more than likely they will need replacing.
2answers
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
these compressors are costly even the parts to maintain.I would first check if you cooling fan for the vsd drive is working which is located in the electrical panel of the compressor.A failing fan or one that has failed would cause this fault
1helpful
2answers
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
3helpful
Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
Top Hitachi Air Tools & Compressors Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
