Get in vehicle before turning key to 1st position, press in & hold odometor reset button while holding in turn key to position 1. after a few seconds reset will appear on screen release & push in again. it will ask you if you would like to reset, press again.
Hi Mike. The lights are the service maintenance lights. When an oil service or inspection service is performed the lights should be reset to all green. Over time the lights will go from all green lights and disappear until a yellow light comes on. The yellow means the next service is due. The red means over due.
Try this procedure and let me know if it does not work.
1. Ignition key in the "Off" or "0" position.
2. Press and hold the odometer button and turn the ignition key to the "Accessory" or "1" position.
3. Keep the odometer button pressed in until you see the following words in the display, "oil service", or "inspection" with "reset" or "re".
4. Press and hold down the odometer button again until "reset" or "re" flash.
5. While the display is flashing, press the odometer button again briefly but do not hold it down this time to reset the service interval indicator. After the display has shown a new service interval then "END SIA" should appear in the display for two seconds.
If the procedure fails the first time then repeat the procedure and it should clear the service interval indicator.
check the owner operater manuel , if a what frequency that lite is supposed to come on at could be you need to change the setting. if so those instuctions shoul be in that manuel
Your BMW has a CBS (conditions based service) system, this is a new standard system for all BMW's produced in 2005 and on, these CBS system cannot be reset without being hooked up at the dealer, there is no currently offered aftermarket tool for this operation that I know of. I understand the frustration of this problem, I own a 2006 325i, with the same CBS system. Hope this helps, let me know
turn the key to the on possition and hit the gas pedle 3 times then the oil light should flash at you and then turn the key off oil light should be reset
BMW insp. reset
-Ingnition OFF (pos 0)
-Press and Hold the trip odometer button while turning key to position 1 (accessory)
-Keep the button depressed (about 5 secs.) imto; upi see "Oil Service" or "Inspeciton" with "Reset" or "Re" in the display
-*Note: ON vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
-Press the button again and hold for approx. 5 secs. imto; :Reset" or "Re flashes
-While the display is flashing, briefly press the button again to reset
the Service Interval. After the display has shown the new interval you
should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
2001 up to 2003 for shure don't know about any other models,
where i found this it said 2001 to current but not shure when it was
posted. Thanks
