I have a Frigidaire Fridge/freezer model FRT18IL6DBB which is about 4.5 years old. At first I thought the light bulb had blown so I replaced it only to realize that the whole unit was behaving like it had no power. after a few hours it was back to normal, then a while later it had shut down again. The shutdown times increased to about 6-7 hours. Now after losing a load of food and having to use the beer fridge in the garage it seems to be working consistently again.
Any thoughts before I risk moving all my food back in???
Thanks.
Every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
