Samsung WF337AA Front Load Washer Logo
Posted on Sep 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer shakes violently and crawls forward - so far forward as to unplug itself. Help !
Samyfam
Level 3:
  • Master 379 Answers
  • Posted on Sep 22, 2009
Samyfam
Master
Level 3:
Answers
379
Questions
Helped
207590
Points
1164
Sounds like a broken damper.
The drum assembly inside a front loader is noramlly supported by two or more big springs on the top, and two damper units underneath. If either or both of the damper units fail, the machine will still work but when spinning, the drum assembly will be able to move excessively causing serious vibartion - as you describe, quite often the whole machine leaps about !
If your comfortable working on washing machines, and can get hold of spares for your machine, then it isnt too bad a job. Otherwise, call an engineer !
Shaking GE Profile Washer
level the machine and make sure the floor is sturdy, you can even put a piece of plyboard under it.
I have a 10" ROK tile saw which shakes violently
MAKE SURE THE BLADE IS RUNNING TRUE, UNPLUG SAW ! BRING THE BLADE DOWN TO THE CUTTING DECK, WITH YOUR HAND TURN THE BLADE, AND WATCH WHAT THE BLADE DOES. THERE SHOULD BE NO SID TO SIDE OR UP AND DOWN MOVEMENT IN THE BLADE ! THERE IS LITTLE WASHER KITS THAT MAKE CENTER THE BLADE TO THE DRIVE. OR IF THE BLADE WIGGLES WHEN ALL IS CENTERED, IT MAY BE A BAD BEARING IN THE BLADE HEAD.... IF I WAS OF HELP HIT THE YES BUTTON.. THANKS JAY.. THE MOTOR REPAIR GUY IN LONGWOOD FLORIDA
1helpful
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
7helpful
3answers
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
My Kenmore 80 series washer shakes uncontrollably in spin cycle.
try this
the washer needs to be leveled on a flat surface to properly function rock forwards then backwards
washing machine have stablizers on there leg pegs this insures it has a proper setting on floor
if this did not help there is a spring under neith that you did not load back to bucket to keep in place
most likely it just needs to be rocked you will know if pegs are seated properly
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
1helpful
2answers
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
