Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
In life fitness next generation operation elevation is not working.!What is the problem?
    Problem Solver:
  • 11 Answers
It will be one of three things: #1 faulty Wax/Lift circuit board that controls the lift motor,#2 the motor itself, or #3 a faulty home switch, which is the white plastic switch in the base of the machine which senses the home position or zero degrees elevation.
Posted on Apr 27, 2010
SOURCE:
Life fitness 9500hr?it wont start and says ....see maintance on display?any ideas
just bought a amazing model after reding review on this site thanks amazon rock http://www.pianoforall-review.com/life-fitness-treadmill-reviews-does-it-works/
Dec 03, 2012 | Life Fitness 9100 Next Generation...
Incline not working
Dear Sir:
Please RUN the software calibration for diagnose, troubleshooting, and fix.
2) LUBE the deck belt, the proble is shut down because enough friction produce from worn deck. In order to protect the electronic system, the machine shut down.Proceed in accordint with the instruction manual.
3) The software c, will guide you what is wrong with the elevation motor.a)try to lube the motor gear b) adjust the potentiomente,c) tigh the connector wires from elevation motor.d) some machine has relais for up and down, clean the contacts.
See my personal TIPS for HELP.
sincerely. God bless you.
Apr 28, 2012 | Life Fitness Tr9500hr Next Generation...
9500hr treadmill said "notify maintenance
Your treadmill is notifying you that some maintenance operation has to be performed.
Nov 21, 2017 | Life Fitness 9500HR Treadmill Next...
INCLINE ERROR ON LIFE FITNESS 95 T TREAD??
hi
check the home switch
it is indicator of elevation
when you look under the tredmill where elevation motor you will see white plastick pin coming down through the hole just check it if still there and pressed it is usually 95 % of elevation problems
if it is not then open the hood and check elevation connections
let me know if it is not these problems post it i will give you system check code
thank you and good luck
Dec 04, 2010 | Life Fitness Exercise & Fitness
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
Aug 13, 2010 | Life Fitness 9100 Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
I need book from cardio life fitness 9000
Send an e-mail to info@fitnessgt.com to request the Life Fitness 9000 manual for free.
Feb 18, 2010 | Life Fitness 9000 Next Generation...
My 9500 next generation treadmill elevation not working
Usually its the display panel not sending the proper signal - look under the display panel on the left side if standing on the belt, there is an access opening and there will be 3 plugs or connectors, it is the smaller 2 prong connector, just unplug and replug to clear the connection, that usually fixes mine, while in there unplug and replug all 3 plugs just to be safe.
Oct 23, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
173 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
