The D60 won't save pictures anywhere other than the memory card. If you can playback your pictures by pressing the playback button (marked with a right-pointing triangle), then they are saved on the card.
The display on the back is for the menus, reviewing pictures already taken, and shooting information. The D60 works as SLRs have worked for half a century: you use the viewfinder to compose your picture. The LiveView feature is a recent development in digital SLRs. Nikon introduced it into their cameras with the D3 and D300. The D60 is designed as an introductory model and lacks this feature. Sorry if that wasn't the answer you wanted to see, but there it is.
The D60 works as SLRs have worked for half a century, using the viewfinder to compose photos. Only recent dSLRs provide the Live View capability, allowing you to use the monitor for that purpose. Nikon introduced this feature with the D3 and the D300. Currently, the least-expensive Nikon with this feature is the D5000.
You could set the white balance to the full sun setting. You could set the ISO to a lower number. You could set the "exposure compensation" to a lower number.
No, you have done nothing wrong. The D60 does not have the preview function on the monitor like the compact digital cameras. Nikon gave that function a name. It is called 'Live View'. The newr models like the D90 do have that feature. You can read further about your D60 here: www.digitalcamera-hq.com
When you are in the playback mode, press the up or down arrow on the back dial until the screen scrolls through the various overlays until you get to the screen you want...usually the screen with the frame numbers on it. If this helps, please rate accordingly, thanks.
Your exposure is set way too high maybe?, If you are using the manual function then turn the round slider located right beside the ae-l and af-l button to the right until picture sorts itself out. Or use the twist function settings ontop of the camera and set it to AUTO. If neither of these works then try going into the menu and selecting reset, do not worry this will not delete your pictures, then then try it out.
Hope it works and you can get back to taking some good pictures!
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
