It really depends on which model 455 rancher you have. The "455e" models have a lever on the chain cover that you lift and turn counterclockwise in order to remove. The regular 455 models have two nuts that you remove in order to take the chain cover off. There is also a chain tensioner on both. On the 455e model you turn the wheel down to increase tension and on the 455 you turn the screw below the foremost nut to tension. Remember that you want to just snug the chain to the bar. You should be able to rotate the chain around the bar by hand.
Unscrew the cover
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-cover-and.html
How to Remove Timing Chain and Gears on Toyota Previa?
http://technoanswers.blogspot.com/2011/12/how-to-remove-timing-chain-and-gears-on.html
Ford Mondeo ST220 camshaft Timing specifications?
http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
------------Replacing Timing Chain Cover For 2009
Ford?
http://repairhelpcenter.blogspot.in/2012/03/replacing-timing-chain-cover-ford-2009.html
Timing Chains & Front Cover Removal on
2008 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/timing-chains-front-cover-removal-on.html
----------How to Replace Timing Chain Cover, Chain,
Sprockets, & Seal On Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-cover-chain.html
---------How to Replace Timing Chain &
Sprockets on Ford Windstar?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
---------Timing Chain &
Sprockets Replacing on Ford, Mercury and Lincoln?
http://fordrepairhelp.blogspot.in/2012/03/timing-chain-sprockets-replacing-on.html
Chain & Sprockets on Ford Edge and Lincoln
MKX?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets.html
------How To Replace Timing Chain, Sprockets
& Front Cover on Ford Expedition and Lincoln Navigator?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-timing-chain-sprockets_356.html
---------Timing Chain,
Sprockets, Front Cover & Seal removal for Ford Mustang?
http://schematicsdiagram.blogspot.in/2012/03/timing-chain-sprockets-front-cover-seal.html
Chain on Buick LaCrosse?
http://howtobyme.blogspot.in/2012/03/how-to-replace-timing-chain-on-buick.html
---------These details will help.For more help keep updated.Thanks.
Removal & Installation
3.5L Engine
Fig. Timing belt routing and timing marks-3.5L Engine
Fig. Timing belt and related components-3.5L Engine
Fig. Adjusting the tensioner pulley-3.5L Engine
Fig. Measuring the auto tensioner rod-3.5L Engine
Kia_Sedona_2002-2006
Timing Chain, Sprockets, Front Cover & Seal
3.8L Engine
Fig. Timing chain and related components-3.8L Engine
Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
Fig. Sealant application (1 inch bead width)-3.8L Engine
Fig. Timing cover sealant application-3.8L Engine
Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
Fig. Timing cover bolt torque sequence and specification-3.8L Engine
