I got a sony 898 amp for free from a friend. The amp was dropped and the body slightly bend. It powers up 100% , I can access all menus. BUT when I plug in the coax cable from DVD or RCA cables it only play 2CH sound. When I do sound test - no sound from speakers. If I set it to ANY other sound option but 2ch there is no sound. The optical input at back shows red as well. I worked through the whole menu to try every setup option - no go
Mario from Namibia(Africa)
I understand that you have tried connecting different audio source to the Receiver as some of the audio source will output only 2 channel audio.
I hope you have tried changing the Input mode and Input selector to get the surround sound.
Please disconnect the speakers with the receiver and clean the edges of receiver and speaker cables using solution like alcohol and try.
If the issue persists, please interchange the rear speakers with front speakers and vice versa and check if audio is coming to make sure that the speakers are working fine.
If the audio comes after replacing the speakers but not from surround speakers, the receiver requires service.
