Question about Sony SPP 933 Cordless Phone
Maybe one or two of the buttons work on the phone. I have to put it on speakerphone to dial out then pick up the phone and turn speakerphone off. Can my phone be fixed if not is there any way to get a new one like it. I really hate change. So I would like to keep the same phone if possible.
When I dial out on my 1983 darth vader speakerphone all I get is a busy signal. Anyone have any idea how to fix this?
This phone was made when most phone companies were still using non touchstone systems. When you dial you can hear it simulate an older rotary dial phone. This was how the earliest touch button phones worked. I am not sure the phone company''s systems are still compatible with the rotary systems. Mine does the same thing when dialing out, but receives a call perfectly.
Sep 30, 2013 | Vintage 1983 Darth Vader Speakerphone...
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
How do we set Personal speed dialling on KX-T7730?
Down the right side of the phone you have 12 Personal Feature buttons. Also, from the intercom, dial "9" and see if you get an outside line. If you don't, you need to fix that in system programming.
Now, from your phone, press PROGRAM, one of the 12 right side buttons, and dial "9" plus the number you want and STORE. You can continue programming all 12 buttons and when you're done, pick up the handset and drop it back down to exit programming.
You dial them by pressing speakerphone or picking up the handset and pressing the button.
Carl
Oct 20, 2010 | Panasonic KX-T7730 Corded Phone
My phone is stuck on speakerphone. When I pick up...
There are two things to check that you can fix. First, try replacing the handset (curly) cord. A broken wire in the cord can make this happen. If that's not it, watch the hookswitch. That's the plunger that goes down when you put the handset in the cradle, and pops back up when you lift the handset. If it's stuck down, you will only get speaker and no sound in/out of the handset.
May 21, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
Need instructions to program Living Solutions Speakerphone ATC-355
living solutions desktop phone (model unk) programing.
turn on with speakerphone button
hit store button once
enter phone #
hit memory button ( where number is to be stored) once
hit auto button once
to dial stored #'s
kift reciever or turn speakerphone on
hit auto once
hit memory button (where # is stores) once
wait for completion of call
Sep 19, 2009 | Lands Phones
I can not geta dial tone when I pick up the hand set, I have to push the speaker button first, and then pick up hand set,and then push the speaker button again.
This is the receiver button not working properly. The use of the speakerphone button will be the only way that the phone will be able to be off hook, there is no solution for this other then having the receiver button repaired which may be more costly then its worth. Sorry
Apr 13, 2009 | Lands Phones
Can't hear other person when i put my razor on speakerphone
How do the external buttons work on my device?
space.gif space.gif answer.gif gifadjust your volume key.
Oct 22, 2008 | Motorola Mobility RAZR V3
Oncoming phone calls from internal ext go directly to speakerphone instead of ringing
If this is on just your extension, dial 640 without picking up the handset. The phone should beep twice. If not, hang up the phone and let me know. If this is helpful, please post as such.
Apr 29, 2008 | Vodavi 30-Button XTS Telephone
Sony SPP 933 Cordless Phone Logo
43 people viewed this question
Top Sony Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
mark gardner
mark gardner
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
