HP LC3760N 37 in. LCD HDTV Logo
Posted on Sep 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LC3760N power light blinks
When I plug the power cord the power light blinks and nothing shows on the screen. I pluged in my DVD player to see if that would resolve the problem. Also I tried to reset the TV by pressing the Power button for 10 seconds and then plug the power cord. None of these options worked. The power supply inside the TV is LC504-4201CC 161WJQZ.
I think the problem is on the power supply PCB but I don't know how to find which component is gone bad. Any help is really appreciated.
Chi Chu
Level 3:
  • HP Master 8,457 Answers
  • Posted on Sep 22, 2009
Chi Chu
HP Master
Level 3:
Answers
8457
Questions
0
Helped
2822854
Points
26282
Replace the whole board,LCD usally the IC is dead,not like DLP the capacitors,burn most of the time.
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
1helpful
Hi my Samsung R730 wont power up after shutting down when battery was low have tried pluging it in to mains and pressing power button but nothing works
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
1helpful
Compaq presario v6101uswont boot not even start up screen
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
1helpful
Cq60-615dx power problem
2answers
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Comp.will not boot starts screen no signal goes off
What's wrong with my will not com on with power bottonlaptop
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
