SOURCE: Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
Hopefully this will work
SOURCE: My headphones work, my mic does not(at all)
Have you gone to your control panel, and found the "speech recognition" option? If you havent tried it, do that. It wil have you recite a sentence and then should conifgure your mic to your computer. I hope this helps!
SOURCE: my mic is not working on my laotop,vista home premium
you do not need to uninstall any driver..i had the same problem and i just bought a new headset wid a mic so here's what probably your problem is...especially those who can't seem to uninstall their driver..
1. right click on the speaker icon and go to recording devices
2. select any of the microphones in the list
3. click on properties
4. go to the levels tab
5. unmute your microphone and voila..microphone works :)
