The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
The MMS settings are now complete.
