Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Testimonial: "ty very mutch very helpfull indeed will let u know if prb solved"
