My Jawbone connects to my HTC Touch but I can not hear anything on th earpiece. When I switch on my phone to turn hands free off it reboots my phone. Jawbone works on other phones, just not this one. Jawbone worked great on this phone for over 1 year. Last month it no longer works. Please help!
SOURCE: Htc touch charging port stop working
It may be caused by dirt ingress in the port, check for dust and clean out with a soft fine paintbrush (like an artist brush) soaked in pure alchohol, or vodka! Short of that solution, purchase a charger of ebay and place battery in the rear to charge.-
http://cgi.ebay.co.uk/DESKTOP-CRADLE-CHARGER-for-HTC-TOUCH_W0QQitemZ130204421069QQcmdZViewItem?hash=item130204421069&_trksid=p3286.c81.m63.l1177#ebayphotohosting
Kind Regards, ACD
SOURCE: HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
SOURCE: Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off. Try holding both volume buttons at the same time for a second or two. If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up. On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume. My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
SOURCE: my htc touch earpiece stopped working i can use
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if doesnt work then
speaker is faulty just get it replaced it happens sometimes do give me a feed back about it
