You may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
SOURCE: How can I run a setup for my belkin F5D8233-4 without the cd?
No router needs a setup CD to configure.
Configure DHCP on your MAC interface that connects to the router and
check if that interface gets an IP. If you have an IP, then open a web
browser (IE, Firefox, etc, forgot the MAC browser name), and enter the
IP address you had but replace the last one with 1.
Say you got 192.168.2.3, then enter 192.168.2.1 and hit return.
You will need a pasword to login. If you ever changed router password, it will be either blank (type nothing) or admin.
After login, you can configure anything list on left side of the menu.
SOURCE: trying install belkin n150 router.setup router and
Try the following:
1. Make sure your PC is connected to the router directly and the LAN ports are lighting up
2. Reset the router
3. Reset the network adapter on your PC (or just restart the PC)
This should ensure that you are connecting on the LAN port.
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
SOURCE: How do i install my
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still unable to access with above ip then press RESET button for 10 seconds then all settings defaults then you can access it. Let me know if you need further assistance. Thanks for using FixYa.
