When does the fan inside the freezer run? I've noticed the fan blade has not moved in a while. I can spin the fan by hand but the motor does not appear to be working. Is the motor bad?
There should be a switch on the door frame so every time you open the door it switches of the fan,if there is not then check the power supply if theres power to the fan then yes the motors bad..
If this is a F22CW commercial unit, in most commercial freezers, the evap fan is controled by a fan delay "Klixon" type switch. It usually does not let the fan operate untill the evap gets to about 20 degrees. It is located in the evap casing, usually attached to the evap on the end "U" turns. Check this out. It may either be bad or the temp is not being reached to turn the fan on.
Hope this helps.
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
tried to get the answer by clicking on the recommended link. No such website, can u help?
