Acer Aspire 5720-6661 Notebook PC Logo
Posted on Sep 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aser 5738 laptop bluetooth not working on widows 7
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on Sep 22, 2009
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
48576
Points
270
You will probably have to look on the net for a driver that is compatible with windows 7 for your bluetooth device. If you cant find one designed for windows 7 you could try a driver made for vista as many vista drivers work for windows 7 devices as well
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8080
Points
Your laptop probably hasn't got a bluetooth module installed. The bluetooth key is standard on the 5738 but bluetooth isn't. Check the specs on the box & I'll bet bluetooth isn't mentioned.
  • Anonymous Jul 24, 2010
    Sorry, bet still not lost - definitely has a switch and definitely no bluetooth module, though they can be purchased from Acer - about £20 - bit of a fiddle to install though so haven't bothered yet. Also, if it has bluetooth there will be a 'bluetooth certified' sticker on the base mentioning the fact - alongside the wifi one.
I HAVE A ASER NOTEBOOK LAPTOP AND EVERY TIME I
4 an aspire 1 atom, i just extended da warrenty an' sent it 2 Texas 4 them to fix, XD.
Aser ferrari 4005 been running well, then it
Check that you have thermal paste between the processor and the heat-sink it is easy to get at but be caerfull with the fan it only has a short cable.
2helpful
Tengon un problema del caataliftico del honda civic lx 98 que puedo aser traabaja vien pero esque me a salido una lus que dise que tengo problema en el cataliftico que puedo aser ho seran los sen sores que...
si te manda señal al tablero lo mas probable es q tengas catalizador tapado o el flujo limitado por fractura de la "piedra" del catalizador en todo caso necesitas reemplazar el catalizador ya q los sensores detectan este tipo de problema
1helpful
We have a pink aser any way mi friend?s nice drop
I believe the hard drive is in a state of shock which can be cause by the fall. The disk the system is reffering to is the windows operating system disk which some how you aquire will only format you hard drive which mean new installed operating system.
By the way is it Acer Laptop if so please state your model number for refference
4helpful
3answers
Bluetooth not working on acer aspire 5738
Hi tallyman,
you lost bet ...when it has a bluetooth switch it will have a hardware installed.
Best solution is got is a simple call to acer service support,the problem very very simple in 5738 machines they installed foxcom bluetooth device a very much updated version.But the drives in your cd will be broadcom drivers install aspire 3810T model bluetooth drivers.
regards
Ar.Praveen(Architect)
[email protected]
Aser 7520 aspire
If you have no video at all then turn off the laptop. Reseat the memory and then turn the laptop back on with just the AC Adaptor hooked up to see if you get video if not then try reseating the memory into the other slot and try turning it on again to see if you get video. If not then your motherboard may be bad. Just curious though after you turn on the laptop, does the hard drive light keep flickering like its trying to load windows?
Aser inet doesnt work
to a problem like what can I possibly can and we give you?
3answers
Crystal eye aser aspire 5520
Please check in Device Manager > Hardware Settings if the driver is properly working.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
