Toro Lawn Mower With Toro Power Tools Logo
Posted on Sep 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toro self propelled mower rear wheel keeps falling off
My rear wheel keeps falling off my toro lawn mower/
A Miller
Level 3:
  • Toro Master 8,404 Answers
  • Posted on Sep 21, 2009
A Miller
Toro Master
Level 3:
Answers
8404
Questions
Helped
2050962
Points
24677
Are these regular bolt on wheels? Have you changed the nut?
I would expectc to find a "Stover" nut on such an appllication. Stover nuts are similar to "NY-Lock" but without the nylon lock. Rather, Stover (and you have to ask for them at the hardware or auto parts place), are not round and/or have had a certain side portion punched to make the nut hard to put on. Some well meaning back yard mechanics (read me) have 'fixed' the Stover by running a tap through them maning them easier to get onto the threads ... but alas, it didnt stay. That was how I learned about Stover.
Let me know if this helps.
A
I have a toro self propelled rear wheel drive mower, I changed the belt and now it won't let me pull the mower backwards. The self propelled works great.
If the new belt is not the same length as the old one it will cause it the not release properly. Even one eighth of an inch too short.
Oct 31, 2016 • Toro Garden
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
7helpful
2answers
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
5helpful
My Toro self-propelled lawn mower, the right wheel has locked up.
I'll bet the wheel needs to come off, then get cleaned and lubricated. Either that, or a stick or stone has lodged between the wheel and raising/lowering mechanism. Since the mower is a rear-wheel drive, the traction belt/gears are not the problem.
25helpful
2answers
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
1helpful
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
