Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
Anonymous Posted on Sep 21, 2009
I have a John Deere L120 riding mower with a 22 hp Briggs & Stratto v-twin with approx 260 hrs on it. It has been smoking & using around a 1/2 quart of oil for about the last 100 hrs. of use.Would like to know if it's a valve seal problem or do I need to re-ring it. Please email me at [email protected]. Thank you, Mike.
Anonymous
Level 3:
President:
  • Master 583 Answers
  • Posted on Sep 21, 2009
Anonymous
Master
Level 3:
President:
Answers
583
Questions
0
Helped
277081
Points
2071
IF IT WAS MINE , MIKE ,I WOULD USE A HEAVIER GRADE OF OIL-----20--60 OR THERE ABOUTS PLUS PUT A SEAL SOFTENER ADDITIVE IN AS WELL,THERE ARE ANUMBER ON THE MARKET,I USE REDEX INTHIS SITUATION. THOSE TWO THINGSWILL GIVE YOU A COUPLE OF YEARS TO THINK ABOUT IT. "YOUDOIT"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 06, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2025
Points
I ALSO HAVE A L120 THAT HAD THE SAME PROBLEM. I TOOK DOWN THE CRANKCASE A FOUND A CARBONED UP PISTON AND RINGS. I PURCHASED A NEW CRANK CASE AND A NEW SET OF RINGS. HAVENT ASSEMBLED IT YET. ONLY HAD 300 HRS ON IT. BE SURE THE CRANKCASE HAS THE RIGHT CAMSHAFT BEARING BORE FOR YOUR EXISTING CAMSHAFT.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2025
Points
I have a L120 and I am having gas problems. I changed the fuel filter and the gas pump. Mower runs for a while about 5 min. then starts to die. Put choke on full and it just lets it run standing idel only for a bit then dies. Any solutions here?
Bill Linda Rivard
Level 2:
  • Expert 197 Answers
  • Posted on Nov 16, 2009
Bill Linda Rivard
Expert
Level 2:
Answers
197
Questions
0
Helped
191422
Points
477
Solution #2 has a pinched fuel line between fuel tank and frame.First post should do a cylinder leakdown and that would give you a very good idea on seals or rings.
2answers
2answers
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Why does it idle up & down constantly
which v-twin ???
Kawasaki or Briggs or Kohler
but I'd suspect a dirty carb just by your question
2answers
John deere L120 riding mower with IntekV twin 22hp
Try replacing the gas in the fuel system. The manufacturers are telling us that gas over 30 days is considered bad gas.
Good day.
4helpful
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
2answers
Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
Jul 25, 2009 • Garden
2helpful
2answers
John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
4helpful
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 • Garden
Top Briggs & Stratton Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
