Question about Mitsubishi WS-55311 55" Rear Projection Television
Model 55311 Can you pick up digital tv without converter box?
    President:
  • 788 Answers
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Posted on Sep 20, 2009
    President:
  • 1,653 Answers
In short no. You will need to obtain a digital conversion box. The only way to receive digital TV is with a digital receiver that is either built in to your TV or to use a converter.
Posted on Sep 21, 2009
SOURCE:
I have a RCA TV Model L46WD22YX5 it will not read any channels with an antenna, HELP!
The whole USA (years ago now) converted to digital TV signal format from analog (which is what your TV uses), this means that the TV will not pick up any channels without a digital to analog converter box, you can buy them very cheap on eBay.
Nov 24, 2016 | RCA Televison & Video
Will this tv pick up digital channels without a converter box?
if it is a crt TV unit there is every possibility that it is an analogue set and will not pick up digital signals with out a set top box
set top boxes star around $20.00 so get one and then you can use the tv any where
Apr 17, 2016 | Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
Will i need a converter box for this tv?
If you want to receive off-the-air broadcasts (i.e., you have no cable satellite system), then yes, you'll need a digital tuning adapter. This set has only an analog tuner.
If you are on a cable system, you might not need a converter box, but it depends on your cable provider. Some systems still offer basic cable service without a box, and you can see what channels you'll pick up with the TV set for "cable" tuning. Other systems require a digital converter box or "digital transport adapter" for any reception. You'll need to check with your cable provider to find out.
Feb 27, 2011 | RCA F36648 36" TV
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
Is my rca f27442 tv digital compatible?
Sorry no.All CRT(tube tvs) are analog tv.It all digital now,must have Digitial converter box and a roof or digital antena to get the analog tv to get the free DTV digital signal.Or u must cable tv.Only LCD tvs have the digital tuner insidide to pick up the free DTV digital signal without the converter box.
Sep 02, 2010 | RCA F27442 27" TV
Will the Toshiba Model 36A42 work without a converter box?
The short answer is no. The reason for that is because it's an analog TV and has a standard tuner which is now obsolete because of the changes to all digital programming last year. You won't be able to use it with out a converter box. I won't recommend a particular brand or model, that would be your choice. Here is a selection of "boxes" available.
http://www.google.com/products?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=Digital+to+analog+converter+boxes.&um=1&ie=UTF-8&ei=GVSxS9WXE4-CswPd27XKAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg
Mar 30, 2010 | Toshiba 36A42 36" TV
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
283 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
