Question about Pramac Storm 5000 Watt Generator
I got a pramac 5000. Was running fine. Tilted it up for 20 min. to add wheels on it. Now it won't run....starts and immediately dies. I cleaned carb, filter, checked for water in gas and cleaned the plug...I am lost..........
  • 1 more comment
  • langlois_200 Sep 20, 2009
    Well, went outside to start it up and wouldn't crank....I just started it 2 weeks ago. Cleaned everything on it, just puzzled on whats going on with it. It only has 51 hrs on it.
    Plug is still fireing--fire is orange, thinkin its a lil fouled out--not sure.
  • mainlywood May 11, 2010
    how long ago?
3 Suggested Answers
SOURCE:
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Posted on Mar 16, 2010
  • 3 Answers
SOURCE: My 5000 watt Homelite Generator will start on the
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Posted on Jul 24, 2011
What would cause a 85 yamaha big wheel to run for about 20 min then die and not start for about another 20 min?
Check that the breather to the fuel tank is working and not blocked. Also check that the filters on the top of the fuel tap are clean.
May 27, 2015 | Cars & Trucks
What would cause a 85 Yamaha Big Wheel 200 to run for about 20 min. then die and not start again for about 20 min?
Fuel tank breather, check to see if it is clean. Check the filters on the fuel tap.
May 27, 2015 | Yamaha Motorcycles
My onan 4.0 generator will not idle and is back fireing while trying to run it will run fine for ten min then starts trying to die and starts back fireing when I try to keep it running
check for a faulty sump oil switch . check for faulty coil ( magneto on the flywheel) as the time it runs suggests that it is breaking down internally.
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Riding my ttr 250 Runs fine then just dies when ded no headlight starter or anything. I wait 10 mins kick it and starts rides about 2 Mins and dies again what could it be?
Maybe trash in your carb. Take the carb off and clean every hole you can find. Put it back together and reinstall. Should work fine.
Jan 22, 2013 | Garden
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
I have a Honda EG5000x that has been sitting in my garage for the past 10 years. I changed the gas and oil, it started up with about 5 pulls and seemed to run just fine until I plugged my compressor in. It...
Is there a spark? If yes, then the fuel supply is blocked, either in the tank, hose, or carburetor. Enough fuel gets by to run a small load, but a bigger load starves it of fuel. The empty carb bowl makes it hard to start until enough fuel gets into the bowl. Clean the whole fuel system and all should be well. Try turning in all the carb adjustment screws then backing them off to their original positions, that may unclog something before you have to tear the thing down.
Feb 12, 2011 | Pramac Commercial 5000 Watt Honda ...
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Pramac Storm 5000 Watt Generator Logo
62 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
