Dryer sounds like there is changemoving around the drum, but there is nothing inside, the sound is on the outside of the drum (metal on metal sound)
I had the same problem last week on my dryer, turns out that the felt on the drum where its attached to the housing has worn off, my dryer is so old. i did do careful inspection, by sticking my head in the drum and turning it by hand and looking into the seam. it does sound like there was a coin in there, but it was just metal to metal scrapping. im off to my buddys used appliance store to look for a felt seal.plz rate-bozcro
Testimonial: "I know where that part is, the felt, I will look there."
Thank you for this post. My Kenmore Portable Dryer just ran out of extended warranty when it started making a chugging noise. After reading this post, with the dryer unplugged, I stuck my head in to inspect the felt pads. After turning the drum back and forth for a while a coin fell out. Thank GOD, my dryer is only 4 years old. It now works fine. Maybe looking for a foreign object would be the first step if you have this kind of issue. Thanks again for you post.
Dumb question, but where are the seals located? Oh and thanks for answering so quickly.
You have change stuck in one or both of the seals.
