In theory, yes, but you might not ever find one (I don't even know if any manufacturers make them). You can use a double-pole GFCI breaker, but they are very expensive. What are you trying to do? There might be another solution.In theory, yes, but you might not ever find one (I don't even know if any manufacturers make them). You can use a double-pole GFCI breaker, but they are very expensive. What are you trying to do? There might be another solution.
You can't post conmments that contain an email address.
it is a dead short in the wiring
if the plug is anything other than 12 volts -call an accredited electrician
just because it is a trailer doesn't mean that the voltage will not do serious damage top your health
Good News!!! GFI outlets are made to trip when a large amount of power is pulled through them. A GFI is basically a small circuit breaker.Your television set is probably just pulling more amperage than the GFI is rated to handle. That means the GFI is working properly And so is the TV!
A GFI outlet (Ground Fault Interrupt) is actually designed to provide extra protection from electrocution in wet areas where water can come into contact with a hot wire, and as long as the refrigerator is plugged directly into the GFI outlet and is not plugged into the GFI outlet by using any extension cord then there should not be any problem as long as the GFI outlet is not over-loaded with other appliances or large electrical demands. If the GFI outlet is tripping then either there is a faulty appliance or electrical device plugged into the GFI outlet or the GFI outlet is simply over-loaded with too much electrical demand, or the GFI breaker could be faulty. Plugging a refrigerator into a GFI outlet is not bad practice, however over-loading one is and that is what should never be done.
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Check Breaker first, 2nd Check to see if washer is on a gfi receptcle. press reset. If this does not work send me more info on Cir. You might want to test outlet and see if there is power there. Storms can tear up app' s Hope its a simple gfi prob .
If so, it is always recommended that microwave be on it's own breaker with nothing else attached to that breaker. This is due to the typically high current draw (12+ amps) of the oven.
The most important items which should be on a ground fault interrupter are those which may fall into water or get wet, but it's of course never a bad idea to use a GFI.
If this doesn't answer your question, please rephrase it with some more details.
We're happy to help and we appreciate your thoughtful rating of our answer.
