Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Leisure 110 range master right hand (main) oven switch broken.
Main oven switch is broken and have taken apart to replace, removed all wire but thin single (like solder) element wire attached but no connection. Can I cut this to repalce the switch and solder on the new one, or do I need to locate where it finished and repalce this with the switch?
    Scholar:
    New Friend:
  • 69 Answers
Hi Andy,
it looks like you are talking about the "wire" that belongs to the thermostat. Follow the wire and you will find that the other end is in the oven. This is not a commom wire, but it is hollow.
the link below shows you what I mean.
I hope this will help you.
Kind regards, Dik
Oven Thermostats Help Advice Fitting
Posted on Feb 27, 2018
5 Suggested Answers
SOURCE:
  • 188 Answers
SOURCE: Oven will not respond
try pressing the oven regulator knob for a while 3 to 5 seconds on ignition its a safty thing so kids cannot gas themselves all cookers have them. you have to hold it in.
Posted on Mar 26, 2009
SOURCE: Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Posted on May 19, 2009
  • 3 Answers
SOURCE: can you help me find a user guide for leisure
I could copy my handbook of the Users Guide for a Rangemaster 110 Gas appliance if you wish and send it on to you, if that would help.
Posted on Oct 23, 2009
  • 160 Answers
SOURCE: i have a leisure rangemaster 110 double gas oven
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Posted on Dec 18, 2009
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
My range master top right electric oven is turning itself on at full power even with the controls at zero and I have to turn off the main power to stop it. Any help?
with the power off i would check the control switch, as it sounds like it has malfunctioned or shorted out. disconnect it and check with an ohm meter. or.....you need a qualified repairman. good luck
Jan 11, 2015 | Rangemaster Classic 110 (Dual Fuel) Dual...
Leisure rangemaster 110
The switch may be faulty, turn off the power then remove the knob ,it just pulls off and shine a torch in to see if it looks burnt, also smell it often if the switch burns they have a distinct acrid smell.
May 07, 2014 | Kitchen Ranges
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
Main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Nov 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
I have a Rangemaster Leisure 110 the left hand oven lights up, but the flame is very low and will not go to maximum.
common problem, there is a device in the oven called a solenoid/ff device these are safety devices and fail after a few years. replacements can be obtained from main stockist Gas On spares on 0121-585-7799
Apr 04, 2011 | Rangemaster 110 (Gas) Kitchen Range
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Jan 20, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
255 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
