Computers & Internet Logo
Posted on Sep 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard driver
Adeel Ahmad
Level 2:
  • Expert 61 Answers
  • Posted on Sep 20, 2009
Adeel Ahmad
Expert
Level 2:
Answers
61
Questions
0
Helped
23697
Points
155
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
My hard drive will not show up on my laptop when I plug it into the USB port. My USB ports work fine on the laptop because other devices show up. My hard drive was working before, but now it won't show up...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
1helpful
I have a 1tbexternal hdd drive and it stopped working. i tryed to switch the plug and put it on other computer but nothing.....
The Passport has four major components:
* the USB cable
* the power-adapter
Get the part-number and serial-number from the label on your disk-drive, and access the W.D. web-site, and use "check warranty status", to see if W.D. will replace the Passport, at minimal cost to you.
Passport 160GB External USB 2.0 Hard Drive - Black: I have a wd 160g external hard drive and everytime...
right click START ,choose properties,choose taskbar then customize ,and select power surge...and select ALWAYS HIDE
this way you get rid of the pop-up message and just don't worry about it :))
Or
Delete all the USB ports in the devices manager,
then restart the computer to let XP install all the USB ports again. Then go to the first USB port and right click on it and go to properties. Then on the advance tab click on do not show warnings
The WD hard disk 160GB is not recognized after plugging into USB
It is very possible that your BIOS will not support a large hard drive. Without more information on your system it will be hard to diagnose your problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
My 160GB Crossfire is not recognised when connected to any of the USB ports. It used to be, but then I've had some other PC issues recently that meant a forced closure of the PC and I'm concerned that...
When starting the external drive there is not much more than just plugging it in to a USB port and turning it on. The computer should recognize it ( showing something like the window shown here http://attachments.techguy.org/attachments/66120d1129787805/new-device-found2.jpg ) and it will show up in the My Computer area and a green arrow looking icon ( http://home.krb.nsw.edu.au/start/images/USB2.jpg ) When disconnecting an external drive the correct procedure is to left click the arrow in the system tray and select Safely Remove Mass Storage Device (X:) (whatever letter you device shows here)
You may want to test if another computer recognizes the device being plugged in to see if it is still functioning. You may want to also try plugging the device into a different USB port on your computer.
Someone gave me a wd external hard drive. Computer says device is ready for use. Drive is found in device manager but no letter is assigned. All it shows is wd external usb device.
Since it an external device. dependent on the BIOS, some machine will assign a drive letter and some will not, either way, if the machine detect the device. you can use it as is.
1helpful
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
